HXr minimum voltage
RV-HXr
HXr minimum voltage
Post by RV-HXr »
Greetings.
What is the minimum input voltage that the HXr permits? Curious if a backup battery I have on board would be sufficient.
Thank you.
Re: HXr minimum voltage
On a 12V unit, 10 volts, and it will draw more current than at 12. Note that the analog input pull-ups run off a regulator from input power, and that voltage will change if the input power voltage decreases, which could affect sensor inputs that use the pull-ups.
