TIT sensor wiring
ski38off
TIT sensor wiring
Post by ski38off »
Does a TIT sensor wire into one of the Aux inputs? If so, does the second wire from the sensor go to ground?
Thx, Mike
Re: TIT sensor wiring
Normally a TIT input requires special EIS hardware. What kind of sensor is it?
ski38off
Post by ski38off »
I was looking at using your compression style EGT probe, EGT-CF-01. I have a remote mounted R66-4C-LYC-P EIS. I thought the Aux inputs have a setting for TIT. I am playing with adding a turbo to my build and this is one of the loose ends. Worst case I could use one of the EGT inputs for the TIT.
Regular Aux inputs can't read a thermocouple. The TIT settings are for modified versions of the EIS hardware that have one or two modified Aux inputs.
