TIT sensor wiring
Posted: Tue Apr 20, 2021 3:25 pm
by ski38off
Does a TIT sensor wire into one of the Aux inputs? If so, does the second wire from the sensor go to ground?
Thx, Mike
Re: TIT sensor wiring
Posted: Thu Apr 22, 2021 8:59 am
Normally a TIT input requires special EIS hardware. What kind of sensor is it?
Posted: Fri Apr 23, 2021 8:30 pm
by ski38off
I was looking at using your compression style EGT probe, EGT-CF-01. I have a remote mounted R66-4C-LYC-P EIS. I thought the Aux inputs have a setting for TIT. I am playing with adding a turbo to my build and this is one of the loose ends. Worst case I could use one of the EGT inputs for the TIT.
Posted: Fri Apr 23, 2021 11:13 pm
Regular Aux inputs can't read a thermocouple. The TIT settings are for modified versions of the EIS hardware that have one or two modified Aux inputs.
