app support for the Mini?
rv7charlie
Post by rv7charlie »
Any chance that the Mini (specifically the GA) will be able to support a usb>bluetooth interface for the remote app, like the HX? The spousal unit would like to see some pretty attitude graphics while she's deprived of the HX display (about to do some upgrading of the panel and the HX was sold).
Re: app support for the Mini?
The Mini has had the same USB Bluetooth GRT app support since the Option Package 1 (OP1) / Feature Set 1 (FS1) option. You can check SET MENU, Display Unit Maintenance, Options Codes to see if you have this option. If not, get the serial number from the upper right corner of that page and e-mail the number to support to get the option code. The Mini has the same USB limitation as the SX and EX. You will need a USB 2.0 hub to connect a USB Bluetooth dongle to the Mini. The IOGear GBU521 is still the only dongle that we have on our compatibility list.
rv7charlie
Emailed support earlier and they said they'd forward the request to you. ;-)
