Urgrade HS to HX?
CD.
Urgrade HS to HX?
Post by CD. »
I have legacy HX and HS screens in my RV7A. If I find another HX, could I easily upgrade the HS with the new found HX? Or is there a better upgrade without having to modify my panel?
chad
Re: Urgrade HS to HX?
If you find an HX with the same screen size then it would fit right in and use the same connectors. The HX doesn't have a gray code altitude encoder so if you have an old gray code only transponder hooked up to the HS that could be an issue. If you have a GPS attached to the back of the HS there is no way to transfer that to the HX.
