altitude encoding
bobnoffs
altitude encoding
Post by bobnoffs »
i have wired a garmin 327 transponder to my mini. is there something in settings i need to set as the 327 altitude window lights up but doesn't display an altitude.
Sonex1517
Contact:
Re: altitude encoding
Post by Sonex1517 »
I have the same setup. What did you set the GTX to? I think it’s the data format you have to configure.
Robbie Culver
Sonex 1517
Jabiru 3300 Generation 4 powered taildragger
N1517S
First flight 10/10/2015
http://www.sonexfoundation.com
Both the Mini and the GTX have to be configured. We typically use the Fuel/Air Data Z Format as it includes some additional data besides altitude. On the Mini this is configured as Rate 9600 and Output "Fuel/Air Data (Z Format)". On the GTX this is configured as "FADC W/ALT".
