Does anyone have an Engine Performance Table for the standard IO-540-D4A5 used for RV-10?
I have been using a table that someone sent me a while back, but I don't know where it came from and can't trace all the values to Lyco Operator Manual values. This sort of thing isn't useful if you don't trust the values...
Jay
Here's what I have:
Sea
Level
RPM	  55%	        75% 	       Altitude	Delta HP
2000	  23.20	29.40	2000		5
2100	  22.40	28.10	4000		9
2200	  21.50	26.80	6000		13
2300	  20.70	25.70	8000		17
2400	  19.80	24.70	10000	21
2500	  19.30	24.00	12000	25
2600	  18.80	23.30	14000	29
2700	  18.50	22.50
						IO-540-D RV-10 Engine Performance Table?
Re: IO-540-D RV-10 Engine Performance Table?
If I remember I'll bring my table back from the hangar and post it.
But keep in mind there is no correction for mixture setting - the table numbers I used are for best power, about 125 - 150 F rich of peak EGT. The error isn't too bad for other mixture settings anywhere on the rich side, but if you run lean of peak - as I do - the power can be considerably less than shown. But it's a good reference if you only like to run lean of peak - again as I do - when at "safe" power settings, like less than 70%. You can estimate the power setting when lean of peak by noting the change in fuel flow. e.g., if at peak EGT the power is 65% and FF is 12 gal/hr, then if you go lean of peak to 10 gal/hr (20% less) the power will be 20% less, about 52%.
