Arming approach on HS
Bavafa
Post by Bavafa »
Just a note to those who have two GRT screen (one HS and one HX) that are synced and if you arm for an approach on HX, your HS will automatically capture the approach when it sees the active needle and will overwrite the HX that is still waiting for the “execute” button to be pushed essentially arming it. This option has not been released for the HS and hoping GRT will add the same functionality to the HS as the HX
Bavafa
Re: Arming approach on HS
Post by Bavafa »
I was wondering if there will be any new update for the HS as it has been a couple of years or more before we have had an SW update for the HS?
I'm working on an update for the WS and HS with bug fixes and some smaller changes that have been made to the newer systems. We may also need to fix some issues with linking to a Mini as some customers have done. This should be available in a month.
