Mini question
Sonex1517
Contact:
Mini question
Post by Sonex1517 »
Is it possible to update a GRT Mini in the field from one version to another (i.e. to add the GPS map feature - next level up)?
I am assuming not - can this be done at the factory or at all?
thanks and blue skies
Robbie
Robbie Culver
Sonex 1517
Jabiru 3300 Generation 4 powered taildragger
N1517S
First flight 10/10/2015
http://www.sonexfoundation.com
Re: Mini question
The Mini-B has to be sent in to be upgraded to an X or AP.
You can add a magnetometer to a Mini-X by ordering the magnetometer. It doesn't require any changes to the X, you just wire it to the serial port.
You can purchase a MAP upgrade for the Mini-X, or an upgrade from a Mini-X to a Mini-AP, which will be delivered in a special software update. The upgrade from the X to the AP includes a magnetometer if you don't already have one.
Sonex1517
Contact:
Re: Mini question
Post by Sonex1517 »
Robbie Culver
Sonex 1517
N1517S
