EIS 6000 fuel flow output to Garmin 300XL
MSletten
Post by MSletten »
The Garmin 300XL features fuel planning capability, but to get the most out of it requires fuel flow information. The installation manual lists hook up info for Shadin, Arnav and EI fuel flow computers. Given that the EIS 6000 can use EI's fuel flow module, is it possible to output fuel flow data from the EIS in a format the Garmin 300XL can use?
Re: EIS 6000 fuel flow output to Garmin 300XL
No. The EIS only outputs in the GRT EIS format, and the Garmin units don't understand it. The only way to get the EIS fuel flow data to a Garmin is through one of our EFIS displays, which will convert the data to a Shadin Fuel or Fuel/Air Data format.
