Pitch servo: Is this ok?
Posted: Sat Mar 23, 2013 11:56 pm
by AX-O
I am installing the pitch auto pilot servo and noticed that it does not look like the roll auto pilot servo. Seems like the back part of the servo "popped out" or something. is this ok?
Roll servo pic
Pitch servo pic
Thanks for any help,
Axel
Re: Pitch servo: Is this ok?
Posted: Sun Mar 24, 2013 5:41 pm
by Djonesdnd
Just happen to have both servos sitting here, they look the same as yours.
Don Jones
Berkut FG
Posted: Sun Mar 24, 2013 6:14 pm
by AX-O
Posted: Sun Mar 24, 2013 8:22 pm
by Tim2542
The Stepper motor floats and moves in the gear case a small amount and the movement is measured and fed back to the controller so it can know and ask for pitch trim adjustments. Make sure nothing touches or rubs on the motor or it can generate false trim requests.
I learned this the hard way when I mounted a Adel clamp on the servo mount screw holes, took a while to find but I had great help from TT
Tim
Posted: Mon Mar 25, 2013 8:58 pm
by GRTBen
Tim
This is normal, the pitch servo has a trim sensing system in it that mounts the motor to the servo and makes it look like it "floats". It does allow some movement of the motor but that needs to be there to allow the trim sensing to work.
